Old 04-08-2015, 08:03 PM
LightNFast's Avatar
LightNFast LightNFast is offline
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
Originally Posted by xb-60 View Post
If a bracket wasn't currently available to move the shifter and lever forward by 3", then it would have taken Phil Remington two minutes to sketch up a bracket, and an hour for one of the mechanics to make it up and shorten the rods.
OK, I'm over-thinking it
Glen
Glen,
Perhaps you're over-thinking it as well as underestimating it ... because there's no "bracket" involved. The tail-housing design (casting) is what sets the shifter location. Moving the shifter mechanism (and have it fit and operate correctly) with a custom bracket is not so easy, especially on these old external linkage units. Hence all the tail-housing variations Ford produced.
As a side note, if you're building an accurate replica of a 289, you'll need the Galaxie configuration - T10 or Toploader, either will work as the shifter location is the same.
Hope this helps.
