Old 04-13-2015, 08:06 AM
cycleguy55's Avatar
Originally Posted by 750hp View Post
Hi
My Dad and I both have TKO 600s. Mine is behind an FE Contemporary, his is in an Arntz behind a big block Chevy.
I have the 0.64 OD and want the 0.82 OD
He has the 0.82 and wants the 0.64.
Is it as simple as pulling both transmissions, switching the Ford input shaft and bearing retainer with the Chevy part (and vice versa), then bolting the switched gearboxes in place?
Thanks
Craig
I'm no transmission expert but, given the 5th gear assembly part numbers are the same for the Ford and GM variants of the TKO600, it would certainly appear they'd be interchangeable. See page 11 of the Parts Catalog here ==> http://www.tremec.com/anexos/TRPM-TKO-0711_145.pdf
Brian
