Old 04-20-2015, 04:22 AM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Tko
I had to have the shaft shortened on my tko to use with a FE, you can also use a spacer between the bell housing and the trans. On a tko you can reposion the shifter and hopefully it will line up with the current hole in the tunnel. You will also need a new GM clutch to match the out put shaft.
Brent can help you with this and has all the parts....
Jon
The Impossible Only Takes A Little Longer
