Old 04-21-2015, 04:53 PM
SydneyChris SydneyChris is offline
Originally Posted by Gaz64 View Post
Chris,
What bellhousing? and what flywheel?
The throwout bearing has a "stroke" of 10.5mm as per Holden SI.
So if the bearing is back 10mm from it's unloaded position, technically it should work.
Can you move the pressure plate fingers?
What is the clamping force? How does Centreforce rate the pedal feel?
hi Garry,
I got the LS3 and Tremec from Prestons in VIC as a kit, its all VE Commodore (HSV) standard set up.
The pressure plate fingers are not movable when the clutch is bolted in plate. The pedal is simply rock hard, once the play in the MC pushrod has been taken up.
While I bled the MC and slave, it may require more time to fully resolve any air pockets as per Muzza's advice.
Chris
