Old 04-22-2015, 02:37 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Hi Chris,
If your pedal is rock hard, I would consider the system has been bled correctly.
So if the engine, bellhousing and transmission is all HSV (LS3, T56), then I wonder why you can't depress the pedal.
How long has the clutch been assembled on the flywheel prior to first attempt of a "rock hard" pedal?
I have had cars with clutch plate stuck to pressure plate and/or flywheel.
That's why I asked whether you can move a pressure plate finger with your hands or a small prybar etc.
I'm interested in the production date of the clutch plate 13-05-02?
Your thoughts?
Gary
Gary
