Thread: Tire pressures?
Old 04-27-2015, 07:01 AM
Late Apex Late Apex is offline
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
Originally Posted by bobcowan View Post
Street tires start at around 1 psi per 100 pounds of vehicle weight. That varies a bit, depending on tire and wheel combo. But 22-24 psi on each corner will put you in the right ball park.
Very good info. The car has oem wheels and tires, and weighs around 2400 lbs. Thanks!!
Your ride should not be to get from point to point. It should BE the point!
