Thread: Tapping noise
Old 04-28-2015, 09:43 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Neutral
Sean,
If you can run the engine with the rocker cover off, then get a 5-10 thou feeler gauge and slip it between each rocker/valve stem. If you hear a difference, that's the one.
Does it have adjustable valve train, and if so have they been adjusted correctly? You may find one is backing off.
Gary
