Old 05-01-2015, 01:02 AM
SydneyChris SydneyChris is offline
OK.. have the LS3 / LS7 style flywheel, which comes in two parts.. ! and measures approx 120mm high as pictured.
The equivalent measurement for the Centerforce set up is 95mm, a difference of 25mm.
The effect would be a pre-load crush of 28mm on the slave cylinder bearing, which exceeds the 14-17mm recommended.
The SS stands at 90mm overall when measured on the bench.
The bell housing is 150mm long overall and its not going to be possible to change that part as the engine and gearbox mounts are already made up to suit.
Is there a shorter SS available... Look forward to any advice.
With thanks
Chris
