Old 05-01-2015, 09:37 PM
TNTaylor TNTaylor is offline
Cobra Make, Engine: Kirkham 427 Street, Shelby 468 FE
You need a K&N 66-3040 unit. I've used this on several of my FE powered Cobra replicas (2-ERA's, 1 Contemporary, 1 Unique). If the air filter clearance is still a bit too close for your comfort, you can replace the 14X3" air filter with a 14X2.5" to 14X2.75" filter (there are four or five height incremental K&N filters available).
Now, with that said, before you spend any money, you need to see exactly what CFM worth of filter assembly you need to properly feed your engine.
Using the simple formula
A= effective filter area
CID=engine displacement
RPM=maximum RPM expected
Using the CFM formula of height X diameter x 6 x 3.14
Also keep in mind that the 14" extreme top flows 500cfm by itself.
Hope you find this helpful.
Sincerely,
Bill S.
Bill -
Thanks for the info. As noted earlier, I got the R2C bottom plate with 14" x 3" filter.
As for your formulas, here is what I get:
468 x 5500/20839 = 123.5
3" x 14" x 6 x 3,14 = 791
I don't understand what the numbers are telling me, can you help?
Tim
