Thread: Correct Gearing
Old 04-24-2002, 06:25 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Correct Gearing
I need some info and advise. Now that I have finally got my 428CJ running well I have noticed that I have less low end torque since I switched from my 302 w/ a T-5 to a Toploader Close. I am still running 3:73 rear gears and if the chart I used from David Key is correct my trans ratio are as follows:
1st 2nd 3rd 4th
2.32:1 1.69:1 1.29:1 1.00:1
This ratio reminds me of my 3.25 : 1 gears I had behind my old 302 before I replaced them with a 3:73 set up, slow off the line.
Am I expecting too much or should I have gone with a wide ratio trans? Should I change my rear gears to 4.11 : 1 ? What advise is out there on this subject. I intend to drag race and road race some ie: Mid Am N.W. Cobra Club event at Pacific Junction, (between Kansas City and Omaha). Tulsa’s Ford Performance and Shelby’s Meet as well as the Run and Gun in St. Louis.
"Let's roll"
"Be part of Something Good
