Old 05-05-2015, 04:17 PM
genolan genolan is offline
Cobra Make, Engine: Backdraft 1048
Default Starting Problems
This has happened several times over the last two years and doesn't correlate to anything.
After a 45 min run I parked it in the driveway and tried to start it 30 min later no cranking everything else worked. The voltage on the gauge read 12v and dipped .5 and stayed pretty solid when I tried to crank it. I put a jump starter on it and it fired right up. I then turned it off and fired it up with out the jumper no problem. The voltage when running is 14v and the battery is new.
Starter to hot? Any ideas?
Gary
Backdraft 1048
