Old 05-06-2015, 02:10 PM
427cobra65 427cobra65 is offline
Default contemporary cobra coil over help
recently purchased a late model ccx with coil overs front and rear
i noticed the ride height was too low so i stared to investigate
found that the rear spax coil overs are set to max height and the car sits less than 4in. of ground clearence after jacking the the car up found that coil overs
have fully extended to only 13in. that does not seem correct
please help
looking for rear and front coil over size in compression and extension and spring heights and size in lbs
thanks
