Old 05-10-2015, 09:07 AM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Originally Posted by Dwight View Post
remove your cables, check to see they are clean bare metal. Put a little grease on them before installing them.
Dwight
Before you do anything, do this. Wire brush terminals and cable ends, particularly ground.
You likely have a sulfated terminal.
You'd be amazed how a little of this kills your connection. Used to happen all the time on the '68-'69 corvettes due to lousey venting in the battery compartment behind the seat.
The older I get, the faster I was.
