Old 05-10-2015, 10:51 AM
427cobra65 427cobra65 is offline
Originally Posted by legenmetals View Post
I'm using Qa1 adjustables with springs that were on the Konis.I checked the spring rates and they are 300 .lbs each. my car is a contemporary with Jag. rear end. I found that the larger the angle of the shock installation the higher the spring rate that is needed.I will try and dig out the Qa1 part number for you.
I am very interested in the part numbers for the rear qa1 did you use a 10 inch high spring?
is your front end coil over also?
thanks john
