Old 05-13-2015, 05:43 AM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
Put car on jack stands. You will need under car access for some things. Remove seats, parking brake cover and shifter. Remove tunnel. Support rear of engine, then remove driveshaft, trans, bellhousing, clutch from inside car. It helps to use two makeshift studs in two trans mount holes so the trans slides straight aft. Make them by cutting the heads off two long bolts. There is room to put a rolling jack under the trans to aid in sliding it out and in again. Take your time and it's not too bad.
