Old 05-13-2015, 08:03 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I'm guessing you heat damaged the clutch, flywheel and pressure plate, and you may have to replace the clutch and pressure plate. The flywheel can be reground, but it may not fix the problem, as the heat damage may be deep to the surface.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
