Old 05-15-2015, 03:38 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
You can call McLeod and ask for their recommendation as well.
I've bought toploader parts, as well as a tranny from Kee, met and spoke to him several times. A quality guy, businessman. Kind of rare today.
Check the surface of the pressure plate and flywheel to see if the metal looks uniform in color(should be), to check for heat damage. You can measure the metal diameters on the pressure plate to see if it goes 12", if it fits.
Check the release bearing for wear as well. Make sure you know the difference between a 1 1/16" input vs 1 3/8" input shaft.
With the hydraulic release bearing , generally the effort for the clutch is not bad.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
