Old 04-24-2002, 05:55 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Rodney
Tremec rates the TKO for 450 ft lb of torque. It all depends if you hook it up. Use street tires, no problem, you will just sit and spin. Put on a set of slicks and get them to hook hard with 600 ft lb, you will eventually loose third gear.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
