Old 05-19-2015, 05:06 PM
spookypt spookypt is offline
Originally Posted by PeterAllen View Post
Mike, the 240Zs have a custom made bracket to mount the a/c as shown. The picture distorts it a bit - it doesn't protrude as much as appears.
If you are interested I can take some measurements and/or trace a template of the brackets.
Peter, is your pulley set up for 5 or 6 rib belt? I assume 6? What is the belt code for this set up? SPK1875?
I've got some issues with my Daytona belt alignments and seeking to find an answer to make it work. I chew belts due to the AC pump being run using a 5pk pulley (off a suzi jimny diesel would you believe) and the rest being 6pk.
The Daytona guys were running a 6pk belt with a rib cut off manually to make it work. DODGY and not what I want for racing. Any suggestions would be super helpful.
Spookypt
