Thread: Psi
Old 05-24-2015, 09:13 AM
turbofanman731 turbofanman731 is offline
Cobra Make, Engine: BDR, #209
I watched the dyno run last weekend and that thing really runs. It's amazing how much different the newer BDR's are from the "older". As far as tire pressure goes the rule of thumb, has always been 1 psi for every 100 lbs of weight. Most tires will heat up a few lbs and give you a good ride and good tire wear. Get too much pressure and the tires will wear out the middle so fast you won't believe it. Especially with all that HP.
