Old 05-25-2015, 01:46 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Hi Chris,
It does take a little more effort to turn the output shaft depending what gear you are in, the clutch may also still be "dragging" since the plate is new.
For example in 4th gear, the input will spin at the same speed as the output shaft while you turn it.
In 1st gear, the input shaft will spin about 3 times output shaft speed.
So in a lower gear it will take more effort to turn the output shaft.
But if you can turn it by hand (clutch pedal depressed), and can't turn it (clutch pedal released), then you must be ready for a test drive.
Gary
Gary
