  #28 (permalink)
Old 05-25-2015, 05:41 PM
CriticalMass CriticalMass is offline
Cobra Make, Engine: ERA #164 427 Med Rise Side-Oiler, 4 Speed Toploader
I had to take a few days off from working on the car, but I have everything back together up to the driveshaft going back in.
I couldn't find a definitive answer from searching...does the transmission output shaft get greased before slipping the driveshaft sleeve on?
Also, should the outer diameter of the driveshaft sleeve be lubricated?
If so, I assume regular chassis/bearing grease is appropriate?
