Old 05-26-2015, 04:11 AM
SydneyChris SydneyChris is offline
hi Gaz,
A quick follow up to validate and cross check (and no I wasnt a hostie in a previous life.. ) !!
I tried turning the output shaft in a number of different gears... validated what you said.. the clutch is working as best I can tell.. .
One thing I noticed when bolting down the mounts for the gearbox tonight was that there is an offset to the centre line of the car for this mount of around 5mm (left to right side).
I recall the guy who set this up originally saying something about a slight offset to ensure the tail shaft was not directly square with the diff centre so the universal joints were under some load at all times.
Are you able to confirm if this (mis)alignment is appropriate and its ok to proceed with the balance of the reassembly..?
With thanks
Chris
