Old 05-26-2015, 12:55 PM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
He has a Toploader. But, if you are inclined to put a NSS in your SPF with your Tremec, make sure you include a NSS bypass as the internal Tremec switch tends to fail, especially if you're not using a separate relay with the switch to activate your starter solenoid (and thus lessen the current going through your NSS).
I was not aware that they had a tendency to fail. If it is a known problem I would expect Tremec to fix it over time.
Bill
