Old 05-30-2015, 09:43 AM
DanEC's Avatar
DanEC DanEC is offline
Finished installing but going to have to wait for the weather to dry up to test it out. I decided to use a regular gasket below the plate and my 3/16 inch composite insulator gasket above. The 3/16 inch gaskets have bolt reinforcements to help control compression and tightening the base plate bolts which I like. If I put another aluminum spacer and gasket in the stack I would be down to about 3/16 inch clearance from the hood to my air cleaner acorn nut so I'm going to try it this way first.
Not much to see from the passenger side.
ERA 782 Running
