351W/427 ci producing approximate 600 HP
My information is based off of my Keith Craft built engine in my Mk III Cobra 427. It has an aggressive cam with a 780 cfm carb on top through a TREMEC 5-speed with a 3.42 final drive. As mentioned by several before me; a number of factors will effect gas mileage. With this set-up you will see 12 - 16 MPG, but can be as low as 8 MPG. I believe the 5-speed transmission helps a little if not just to keep the engine from turning so many RPMs at highway speed. I hope this helps with your decision process.
SPO 3098
