Thread: 8 stack system
Old 06-01-2015, 05:46 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Dwight,
I understand the front of your system, but the check valve you have in the return line?
There should be NO restriction between the regulator return port and the fuel tank.
To me, the check valve you are referring to would be in the main line after the pump as a non-return valve.
Gary
