Old 06-02-2015, 07:20 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
-- SSBC Brake calipers, these are similar if not the ones I used. Summit has a pretty liberal return policy, so if you bolt them on and there is wheel interference I'm confident you'd be able to return them.
http://www.summitracing.com/search/b...oview=SKU&ar=1
-- A Summit Racing version of the braided stainless steel lines. I think all I did was check the manufacturer's length against what was on my ERA, and then reviewed the fittings to make sure I could connect both ends.
http://www.summitracing.com/parts/su...t/model/camaro
-- These are the Wilwood reservoirs I use. I purchased three of these and mounted them in direct replacement of the Girling tin cans. They are roughly the same size as the "useful" volume of the Girling cans. I added braided lines down to my steel lines which required new fittings, but I don't have any leaks or issues. (I also am not a big fan of the rubber lines that went from the reservoir to the steel lines, but braided lines here are certainly overkill/overengineering on my part.)
http://www.summitracing.com/parts/wi...2697/overview/
Dangerous Doug
"You're kidding, right?"
