Old 06-02-2015, 03:40 PM
joyridin''s Avatar
joyridin' joyridin' is offline
Your suspension is set-up almost exactly like mine was. The strut rods in the rear, the lower aluminum support, the Koni's up front, and the sway bars are exactly the same.
Your interior and body look like an earlier version though. Your gauges are in different locations, you do not have the notch in the hood, your gas cap is in the center, and a few other things are different. Your engine seems to sit further forward than mine also. Mine is a very late Arntz Type 3. Yours maybe a late Type 2 or earlier Type 3?
If you read all the posts in the Arntz forum, there is an explanation of the different types. You can usually tell by the door hinges and door braces along with a few other noticeable items.
