Old 06-04-2015, 08:57 AM
wrist_pin's Avatar
wrist_pin wrist_pin is offline
Cobra Make, Engine: Perhaps someday; Ford 4.736 litre - formerly locked up but I've successfully disassembled it completely w/o destroying anything
Thanks Mark.
I had to look this up.
Speedy Metals Information for 3003-H14 Aluminum
3003 Aluminum is alloyed with 1.20% manganese, which increases the strength of 3003 over commercially pure aluminum (1100 series). 3003 has excellent workability, weldability, and good corrosion resistance. It is used for drawing, forming, spinning, fuel tanks, sheet metal works and other applications that require moderate strength for an aluminum with good weldability. H14 designates the temper, and means that 3003 has been strain hardened and partially annealed. In this condition, 3003 can be easily formed.
I have been following you on metalmeet. You are doing some pretty work.
MAStuart's My Daytona Coupe (cobra) scratch build
Do you have a guesstimate as to the total weight of the body when finished?
Forrest
Do WhatUCan, with WhatUHave, where UR -T Roosevelt
