Old 06-05-2015, 12:39 PM
leroy17's Avatar
leroy17 leroy17 is offline
No worries.
I am either going to weld brackets onto the chassis. Or most likely use some box tubing and bolt to the original drilled mounts in the chassis, then align and drill the two flats of the box so it aligns through the first and second hole and is secured at the exit of the second hole (if that makes sense).
If I don't get lazy, then my preference is welding tubes to the chassis so the quick jack rods mount through the tubes.
