Old 06-06-2015, 06:46 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
If I understood Bob correctly, it sounds like the clutch has it's own fluid storage in the BMW reservoir. Without having seen one, what I suspect is that there are two dividers in the bottom half of the reservoir that creates 3 fluid chambers. As long as the fluid level in the reservoir is maintained above the dividers, all the chambers stay full. If the front brakes loose a caliper seal and fluid, the reservoir level would fall to the level of the dividers and the fluid in the front brake chamber would continue to fall until the master cylinder sucks air. But the rear brake chambers and the clutch chamber would still have their fluid chambers full up to the dividers and continue to operate normally and have some fluid reserve. Not sure if this is correct but sounds like the approach.
You should not lose the clutch due to losing one of your brake circuits. You should not lose the brakes due to losing the clutch circuit. All three have some independence and redundancy in terms of reservoir storage if one does develop a leak.
No, not at all. there is only one divider in the bottom. The clutch part of the res is the upper section. The clutch line draws off the middle of the res, (by middle I mean height-wise), so that is basically the clutch compartment. Now the bottom of the res just has a separator wall going across it, thus creating two more compartments. At the bottom of each, there is a brake line, one going to the fronts, and one going to the rear. Now if you blow either your front or your rear brakes, you will definitely lose all your clutch fluid in the res because the brake lines and compartments are located and draw from the bottom! I just found this pic online. You can't see the bottom two lines because they go directly into the foot-box on their way to the master cyls. EDIT: For some reason the site wont upload the pic, first time I have ever had that problem??? If you google images "ERA cobra brake clutch fluid reservoir", it will be one of the first pics. Here is the address.
https://www.google.com/search?q=era+...id%20reservoir
OK, so if you understand it better now back to my question. which was, do you think that if you lost your clutch fluid because of a brake line leak in the single reservoir system, would you have enough in the clutch master to shift the car for a while? If it was to return some fluid to the reservoir every time you released the pedal, you would be screwed shortly because of the brake leak.
Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
