Old 06-07-2015, 07:21 AM
Mark Brye's Avatar
Mark Brye Mark Brye is offline
Cobra Make, Engine: BDR354/FMS392
My car came with the wilwood pull style slave. Over the first several thousand miles I went through three of them. The first slave failed because of the seal. The next two I had problems with the shaft comimg unscrewed at the piston in the cylinder. I then swithed to a cnc co pull slave and it's now been about five years since I had an issue. I just make sure to bleed the fluid every year and I did add a heat shield Early on.
