Old 06-08-2015, 03:47 AM
stephen low's Avatar
stephen low stephen low is offline
Default Long weekend shed update
Some more shed progress over the long weekend.
Despite gales in Melbourne I didn't let a bit of wind get in the way of spraying and hanging more sheets to get the shed closer to completion.
Developed a sneaky series of swings to lay the sheets flat and one paver on each to stop them blowing away and got the right side of the shed as completed as I could.
Swings as mentioned and tied up now waiting for the roof installment.
A bit of after dark photography showing most of the second side completed including and access door as the second last panel.
When I pulled the shed down I discovered the sheets on the right rear and back of the shed had been buried and had rotted away to some extent. So the sheets I've hung are all the good ones.
Plan on buying two sheets to finish up to the rear on the right side as above and then I will do some cut and shut around the rear where it will not be seen.
Also managed to roughly hang the roller door at the end day of today.
Plan on painting the outside rollerdoor face by next weekend and then I can install the tracks and finish installing this door.
Still a bit to go but the shed is progressing.
Can't wait to get it finished so I can turn my full attention to the cobra and get this thread back on real track - lol.
Enjoy
slowy
