Old 06-08-2015, 04:49 PM
jhv48 jhv48 is offline
Have you checked the fluid reservoir to see if it's full?
Is there fluid leaking from the slave under the car?
If you are having to pump the pedal to build up pressure, either the master or slave probably need to be replaced, as fluid is leaking past the seals.
Jim
