Old 06-08-2015, 05:54 PM
SmallSoldier SmallSoldier is offline
Originally Posted by jhv48 View Post
Have you checked the fluid reservoir to see if it's full?
Is there fluid leaking from the slave under the car?
If you are having to pump the pedal to build up pressure, either the master or slave probably need to be replaced, as fluid is leaking past the seals.
I will purchase a new master and slave and replace them for some piece of mind... This is going to be a very silly question, but where is the slave supposed to be located
I haven't checked if there is fluid in the reservoir, there doesn't seem to be a way to check?
Shall I buy both from Wilwood? From what I read in the forum, it seems to be what most do
I apologize for the stupid questions... Finally bought my dream car and just trying to learn more about it (and try to fix it if the difficulty level isn't too high)
Thanks for the questions! As soon as I get back in the states, I will jack up the car and check for any leaks
