Old 06-09-2015, 08:10 AM
cbreez cbreez is offline
Many threads on this...99% of the time the slave is leaking. Leave the master alone and replace the slave with whatever it had on it and live with it till the next time. I find it's easier to refill master from the passenger side, reaching over with a shot glass of fluid.
You can easily bleed by yourself...first drip bleed, then close bleeder, and then pump the heck out of it. (30) This is a very vertical system and most air bubbles will rise to the mc and dissipate. Good Luck.
BTW, brand is not that important, it's just a bad heat problem that ruins the fluid, then the slaves.
