Old 06-09-2015, 03:26 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by cbreez View Post
BTW, brand is not that important, it's just a bad heat problem that ruins the fluid, then the slaves.
Also alignment - if the rod is angled to meet the fork the piston is probably scraping on the bore and wearing it. The fork will always move the rod in a slight arc so you can't achieve perfect alignment - but try to adjust it to the extent the mount provides - to stroke as straight as possible.
ERA 782 Running
