Old 06-11-2015, 11:14 AM
SmallSoldier SmallSoldier is offline
Originally Posted by 6t8stang View Post
I find it easiest to access the clutch master cylinder leaning over the driver's side fender, (head almost upside down). I bought the smallest bottle of fluid available (bottle is only about 4" tall). This allows you to reach behind the brake master, unscrew the cap and pour from the little bottle. Careful not to get fluid on any painted surfaces...
I agree your slave is probably leaking. If Wilwood, they sell rebuild kits to replace the seals. Now would be a good time to switch to a high temp fluid and flush the system. You'll probably find the fluid is pretty dark.
Being built in 2002, you may not have a heat shield beneath the two master cylinders - definitely helps having one. Also look at how the hydraulic line is routed from the master to the slave - might be room for heat shielding as well as these are generally close to the headers.
Thank you! I will take pictures of everything I can find... I always wanted to build a Cobra, but as all of you can tell from my questions, I don't have the knowledge to pull it off... The opportunity came to buy one used at a good price and couldn't let it get away
Part of the reason to buy a Cobra was also to be able to work/wrench on it... It will be a very steep learning curve for me and tons of questions that I will need to ask... Luckily, this forum seems to be full of people eager to help/teach and I'm going through as many threads as possible to start learning (I promise I won't bring threads back from the dead)
