Old 06-12-2015, 07:45 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Originally Posted by davids2toys View Post
Do you have the ERA rear with outboard brakes or the standard rear with inboard brakes? I have the standard rear, so perhaps we are talking to different animals here?
I have just gone thru 2 full days and totally struck out on getting a braided line for the rear. Even Pegasus could not adapt fittings to one of their lines because the female has no circlip provision and the nut is 9/16 and will fall right thru the tab on the frame. Camaro is NG because the threads are 7/16 and I need 3/8.
Also talked to Bob Putnam 2 days ago, he had no info for me either
I have the outboard brakes setup. The flex lines to the calipers are BSS, as is a flex line from the subframe going to the steel lines on the frame. Came from ERA that way as I recall.
You've found a kit for flex lines in the front, yes? On the rear, can you find an adapter that will allow you to mate 7/16 and 3/8?
Dangerous Doug
"You're kidding, right?"
