Old 06-14-2015, 10:28 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Jeff;
If it re-occurs, then after attempting to start the car, touch the positive cable (the insulated part). If it is hot, you probably have a poor ground or a dead spot in the starter windings. If a dead spot, usually bumping the starter will work for a time until you can replace it. But first, run a large ground cable (0 or 00 welding cable with soldered ends my favorite) from the frame to a starter attachment bolt. This last solution worked for me when my car had a similar problem--started fine cold, but was slow or impossible to start hot. Good luck and I hope the fix is cheap and easy!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
