Old 06-21-2015, 10:47 AM
Paul Kane's Avatar
Paul Kane Paul Kane is offline
It appears you've lost the outer ring of your harmonic balancer and have only the inner hub remaining.
Thus far it looks like a common FE-type harmonic balancer that was used on FE engines for over a decade. You could go several different ways with a replacement (OEM, aftermarket, etc). If an identical OEM replacement is what you're after, try giving Damper Dudes a call. On their website I see a couple of different single-groove C3AE harmonic balancers (one with timing marks, one with timing button, etc). A link to their website is below:
DamperDudes.net (Americas Largest supplier of harmonic balancers)
http://www.highflowdynamics.com
