Old 06-22-2015, 08:25 AM
jimbo01 jimbo01 is offline
Cobra Make, Engine: Backdraft #832
I spent the weekend working again on the car. Used the spinner tool to remove the wheels on the Backdraft car. These are the new 18" wheels they are using on all the new cars. The body of the tool is to short for these wheels. In order to make it work you would need to extend the body about 5/8" which would allow the nylon pad to lay flat on the wheel. I broke the nylon pad in attempting to use it as I received it. Using the tool is easy and makes removing the wheels a pleasure. I only wish Craig with Craigs Cobras would make the tool longer for these wheels. I will modify mine to fit as it makes removing them simple. I will try to post pictures of the modification.
