Old 06-23-2015, 05:00 AM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Originally Posted by tortuga View Post
I am a sailboat racer hence am pretty tight with several sailmakers: I am contemplating a sock arrangement made of welders blankets that slip over the pipes forward to the support then are wrapped around and snapped forward of the bracket...At this rate I'll have no calf skin, and the first time the wife does it, well you know what happens then...
Ouch!
The problem with that is how do you remove them from a seated position?
A better solution might be to sew a dowel in both ends. One dowel acts as a weight to hold the blanket over the door jam and the other acts as a weight to pull the blanket down. I see it as put it on, get in and lift it out and roll it up on the dowel.
I am going to try snaps and think about dowels after that.
Bill
