Old 06-24-2015, 04:30 AM
Barry_R Barry_R is offline
If its leaking at the distributor you can add a rubber band (or similar) behind the angle cut O-ring seal to tighten & dry things up.
Check your valve cover breather to make certain it has not become clogged over time. Might need to be replaced or soaked & washed out.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
