  #25 (permalink)
Old 06-27-2015, 06:15 AM
Zedn's Avatar
Zedn Zedn is offline
Fuel pressure is around 60psi. But injectors arnt opening.
Havnt got the service number handy so have to pull the ecu to find out. It's out of a VE commodore 2009. Same as Pontiac 2009 I believe. With a 2009 ls3.
3 wire crank sensor. Should be power, ground, signal. I have 5v on the crank signal wire from the computer. But no voltage on the cam signal wire. I would have thought they would read the same being the same type of sensor. I have posted on some other forums to find out if that's normal.
