Old 04-26-2002, 11:33 AM
Ron61's Avatar
Ron61 Ron61 is offline
Default Coil
Simon,
You can measure the primary resistance of the coil which should be low. Then measure between the primary and secondary and that should be very high. The easiest test is if your coil is easy to change just put in a stock coil with your resistor and see what it does. I use a Jacobs system and their coil and I have a ballast resistor and no problems.
Ron61
