Old 06-28-2015, 02:13 AM
leroy17's Avatar
leroy17 leroy17 is offline
Originally Posted by EB847 View Post
double check your welds. my diff broke off the frame after installing billboards and giving the car a proper work out last week
reinforcing everything suspension related that had the same crappy welds (including the rear arm area i sent you). i will post the after pix in a week or two. and then see what else my race tires can break
Whoa..... I can only imaging the noise and shock that must have been.
It's interesting to see the different shock and diff mounts. Mine has about an inch and a 1/2 drop mount for the diff and the shocks are bolt on plats with tabs.
Either way, I plan on a full strip down and checking welding and may look at braces for certain areas. Keep me posted on your progress.
