Old 06-28-2015, 01:57 PM
blykins blykins is offline
*Factory 390 FE block, bored/honed with torque plates, align honed with ARP main bolts, square decked
*Durabond cam bearings
*Federal Mogul main and rod bearings
*Factory 390 crankshaft, fresh ground
*Factory 390 rods, resized, ARP rod bolts
*Custom Racetec forged pistons
*Mahle 1.5/1.5/3mm ring pack
*Custom Comp Cams hydraulic flat tappet camshaft
*New cam thrust plate/bolt
*Ford Racing timing set
*Ford Racing fuel pump eccentric
*Factory timing cover
*New timing pointer
*New balancer spacer
*Professional Products harmonic balancer
*New balancer bolt
*Crower lifters
*Rotating assembly balanced
*Melling oil pump/pickup/drive
*New factory style front sump oil pan
*Felpro timing cover/head/oil pan/valve cover gaskets/rear main seal
*Mr. Gasket intake gaskets
*Carter fuel pump
*BBM or Survival Motorsports cylinder heads
*ARP head bolts
*Trend pushrods
*SI stainless valves
*Comp Cams valve springs/retainers/seats/locks/seals
*Reburbished factory rocker arms/stands/spacers
*New filter adapter
*Edelbrock Performer RPM intake manifold
*Mallory Unilite distributor
*New distributor clamp
*Quick Fuel Slayer carburetor
*MSD plug wires
*Autolite plugs
*New water pump
*Ford Racing valve covers
*Factory pulleys/alternator bracket
*75A alternator
*Assembled/dyno'd
$9999
Some options...
Hydraulic roller camshaft upgrade - $465
Scat H-beam rod upgrade - $222
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
