Old 06-29-2015, 08:34 AM
tkb289 tkb289 is offline
Back in 2005 or so, when I was spec'ing out my build, I am pretty sure I remember Doug chatting with me that for the FIA (and presumably now the slabside), the hydraulic TOB was the only real option. Since I was having a 427 car built, I didn't dwell on the subject. But I'll ask now, are you absolutely sure that the more recent FIAs and Slabs can now accommodate a traditional external slave and fork?
Good question, I am sure Bob will chime in soon.
In 2011, for ERA2136 (with QT Bell housing / Iron block 302), I went with an external setup from Mike Forte and it fit, don't know if things have changed with the newer ERAs. It was a generic kit, so I did modify the setup slightly to tweak the geometry a bit, to get it to work the way I wanted it to. The hydraulic TOB would probably be easier to install, and should be quite reliable as many production cars use them. The advantage of the external configuration is should it leak, it's a lot easier to fix than the hydraulic TOB. Just one more choice to be made when building a Cobra ...
